My WiFi connections has become extremely slow all of a sudden. What is going on?
Hello@cityfeller , are you referring to the landline at home? If yes and if the Internet connection is active but you struggle to surf it will probably be because the signal is inconsistent. The cause is often the poor quality of the home telephone system and / or the copper line from home to the operator's network.If you are unable to surf in Wi-Fi mode, try to check internet connectivity in another way, using the LAN cable. If you are able to navigate with the LAN cable, the problem may be in the router's Wi-Fi configuration.Also try resetting the modem.
It’s not a land line, it’s wireless.
Hi
Ok, thanks. Do you know what problem is?
Hi
It’s not a cell phone I’m referring to, it’s a wireless router for 4G internet connectivity.
Grazie.
It says WebCube 4G+. It cannot be connected via a LAN cable.
It started two days ago. Service was fine until then. My iPhone is locked and I cannot insert another SIM into it.
Hi
I took the device in to be looked at it turned out to need a firmware upgrade of some kind. It’s fine now. Don’t you have a way to notify users when a firmware upgrade is needed? Users shouldn’t have to take a device into the shop to find this out.
Tony
Accesso al social
